Description
Box compression tester with integral Pc and software dedicated to testing corrugated board boxes and cartons.
Construction
Rigid Moving platen driven by 4 recirculating ballscrews. Platen parallelism better than 1:4000. Load readings are taken from an average of 4 balanced load cells to compensate for the effect of any off centre loading.
Force Measurements
Extension Measurements
 Speed Control
Load Frame
Software
