Description
Standard and wide frame models are available with dual or triple test stations. These models are particularly useful for users who test a varied and consistently changing range of products that involve different grips and load cells etc.
A second test station can be added to FS150 and FS300 models, this is situated at the side of the main loading frame and can be fitted with load cells up to a maximum capacity of 25kN.
The system is ideal where both high and relatively low strength materials need to be tested in that the correct load cells and grips are always fitted ready for testing.
Force Measurements
Extension Measurements
Speed Control
Load Frame
Software
